- This topic has 19 replies, 12 voices, and was last updated 2 months, 3 weeks ago by greg954.
07/06/2024 at 18:21 #199379Ivan SorensenParticipant
So I used to play GW Epic and I’ve admired 6mm figures from a distance for a while but it always seems daunting, particularly having to get a different set of terrain.
So I am asking for the hype-men, the shills and the fanboys: Do your worst 🙂
Sell me on why 6mm is awesome, any genre, any period.
07/06/2024 at 19:16 #199381UsagitsukiParticipantSengoku 'blog: https://tenkafubu608971038.wordpress.com
07/06/2024 at 19:33 #199382Mike HeaddenParticipant6mm
– easy to paint as no detail needed.
– cheap to buy
– possible to field a larger number of figures per base to give a more impressive and realistic image of units
– scenery is smaller and therefore cheaper
Of course 2mm is where it’s really at 🙂
07/06/2024 at 19:52 #199383Mr. AverageParticipantMasses of soldiers on the table look great, and 6mm spans the gap between feeling like a sergeant leading your 28mm troops, feeling like a Lieutenant leading your 15mm scale platoon, and being a General leading your 3mm scale army corps. The 6mm scale is the Colonel leading his battalion, tactical but not micromanaging, and with enough of each level above and below to feel like an engaging game scale all its own.
07/06/2024 at 19:52 #199384Steve JohnsonParticipantWhat Mike said plus battles tend to look like battles, rather than a school trip with 28mm figures (as said by Rick Priestly).
07/06/2024 at 20:08 #199386Ivan SorensenParticipantNow who is gonna hype up 6mm skirmishing? 🙂
07/06/2024 at 20:15 #199389Mr. AverageParticipantAlso me.
It lets you play the same games you like to play at other scales, but on a 12” square base. You can take your games with you! And the wealth of 6mm figures out there are your friends. Like Fantasy? Look at Microworld Games. Like Science Fiction? Go to Vanguard Miniatures. And for the price of a couple packs you’re off and running – the same game you liked before but it didn’t cost you half the gross national product. And if you then set them with magnets and put them on a steel base, you can play both types of games with the same kit.
07/06/2024 at 21:28 #199391WhirlwindParticipantNow who is gonna hype up 6mm skirmishing? 🙂
It is a great size for 1-2 platoon per side skirmishes, play it in true scale, even with vehicles.
07/06/2024 at 21:36 #199392Ivan SorensenParticipantWhat does the typical gaming table come out to in 6mm? 3-400 meters across?
07/06/2024 at 22:42 #199393Mr. AverageParticipantDepends on ground scale. Anything from about 300 yards to a mile or two.
07/06/2024 at 23:10 #199394Ivan SorensenParticipantOh sorry, I meant if you are using “true” ground scale for the miniatures.
08/06/2024 at 00:05 #199395MikeKeymaster08/06/2024 at 04:17 #199400PunkrabbittParticipantIvan
____
6mm
FOR SALE!!!!
There you are, on 6mm, being sold.
Please visit my OSR products for sale at
www.drivethrurpg.com/browse/pub/17194/Punkrabbitt-Publishing08/06/2024 at 09:52 #199406UsagitsukiParticipantWhat does the typical gaming table come out to in 6mm? 3-400 meters across?
About that for a 1.2m table, depending on what scale you use for 6mm. This was a battle on a 1.2 x 1.8m table with a 1:1 figure scale, and 1:250 ground scale.
08/06/2024 at 18:24 #199424Ivan SorensenParticipantThat is lovely (and thank you as well)
08/06/2024 at 20:34 #199428WhirlwindParticipant.
Yes, about that. I use either 1cm = 2m or 3m, or 4cm = 10m as all in the ‘more-or-less’ true scale. For my typical small board games (on a 2’x2′ or 3’x2′), that works out as up to 270m x 180m. Double that for a ‘typical’ medium-sized board.
10/06/2024 at 14:56 #199461Darkest Star GamesParticipant6mm practically sells itself!
I too skirmish with singly based figs in 6mm, works a treat. A lot less expensive to field a wide variety of troops and vehicles, you can use realistic ranges for post industrial revolution types if you want to (which means you don’t necessarily have to use a smaller table), and can immediately translate to bigger battles without having to change scales. Plus, takes up less storage space (just sayin…).
12/06/2024 at 08:12 #199525MartinRParticipant6mm. Cheap, easy to paint, easy to store, easy to transport, looks great and is a simple way to put together armies for a peripheral period. Did I say it is cheap?
I also find them easier to handle with my big fat fingers than 2mm, which even when based, is a bit fiddly.
13/06/2024 at 11:58 #199576ThuseldParticipantI do the single based skirmishing in 6mm. I love that I can fit a small game in a small area.
Experiments here: http://inexperiencedmodelmaker.blogspot.co.uk/
Tranquil Stars updates: https://tranquilstars.wordpress.com
13/06/2024 at 15:26 #199582greg954ParticipantI just liked the models which were available at the time to buy (Scfi). Storage was convenient, not to mention I never found it took too long painting.
6mm skirmish? Sci-fi? I have a dim awareness of this…
Ah, yes, me too. Anvils Gate comes to mind…..not to mention 6mm Scfi is a joy to scratch build in. Doesn’t take a huge bits box and those Robinson fruit shoot drinks caps were widely used by someone on here….Used for habitation units 🙂
