- This topic has 12 replies, 12 voices, and was last updated 2 weeks, 5 days ago by OotKust.
09/07/2024 at 22:49 #200445MikeKeymaster09/07/2024 at 23:54 #200446Mike HeaddenParticipant
Spray varnish once the whole things is complete. Dabs of paint-on varnish if bits need to be shinier/ less shiny. That’s it for me.
10/07/2024 at 04:38 #200452mark leslieParticipantThe first rule of Varnish Protocol is you don’t talk about Varnish Protocol.
I don’t usually but when painting mounted figures (15mm and up) as one piece I have been known to paint the horse and varnish it then paint the rider.
We all have our foibles, some are more foibly than others.
Fossilizing nicely.
10/07/2024 at 07:45 #200455MartinRParticipantI very rarely bother with varnish these days apart from on 20mm plastics and to take the shine off decals. I just do it at the end.
10/07/2024 at 07:58 #200456willzParticipantGenerally varnish after all painting complete but before metal is painted.
Never spray always use a brush.
10/07/2024 at 08:25 #200457Not Connard SageParticipantQuick blast of Testor’s matt, job’s a good ‘un. 🙂
10/07/2024 at 08:44 #200458Sane MaxParticipantBecause I am an oddball my Varnish Doctrine is set in stone and cannot be deviated from.
I paint a few dozen bases. I will then apply Yacht Varnish. They then go sit on a shelf to dry for a week. As a result when I have the painting Mojo there may well be several batches waiting the second coat, of Matt varnish, and I even sometimes have to label the trays so I know who is next.
But I no longer Varnish Plastics and I have been painting quite a lot of them recently. my last big army was entirely, 100% plastic. This would have been a spectacularly light army to transport, and would have had the advantage of not chipping each other in the case, had I not for some stupid reason based them on tuppences rather than using the huge stock of plastic 25mm round bases I already owned. Doh.
10/07/2024 at 09:39 #200459bobmParticipantI complete all painting, leave for 24 hours minimum then brush on Liquitex matt varnish. “Metal” is not as shiny as many think…If highlighted at the painting stage pre-varnish it still looks like metal after matt varnish is applied.
10/07/2024 at 15:44 #200470Darkest Star GamesParticipantI paint, hit with gloss coat varnish, ink/wash and highlight if needed, then hit with gloss then dull coat. Very rarely have any chips unless the figure plumets to hard flooring.
11/07/2024 at 12:19 #200508John TreadawayParticipantI used to use Testors religiously but had some bad reactions from it after using over Army Painter Dip. I use spray now (Pebeo Matt Picture Varnish Spray) but – unless I’m using speed paint version 1 where I spray at various stages to avoid bleed) I spray at the end. Like DSG I use a gloss varnish if I’m putting down decals (usually a coat if Future floor polish) but then matt spray at the end.
I find the varnish seems to ‘unify’; a modle’s finish and the Pebeo is very matt and does a good job.
John Treadaway
www.hammers-slammers.com
"They don't have to like us, snake, they just have t' make the payment schedule" Lt Cooter - Hammer's Slammers
http://www.hammers-slammers.com11/07/2024 at 14:21 #200511Darkest Star GamesParticipantLike DSG I use a gloss varnish if I’m putting down decals (usually a coat if Future floor polish) but then matt spray at the end.
Future is an absolute must for the decals, for sure! Reminds me I need to find a new bottle as mine has yellowed in the last month, and that does make a difference.
11/07/2024 at 18:13 #200531Geof DowntonParticipantAlways Winsor and Newton matt, spray or brush, because a remover exists, for when I discover the bit of flock or ststic grass. Usually on top of GW ‘Ardcoat, applied by brush 24+ hours following painting but before basing.
Ahab, King of Israel; 1 Kings 20:1112/07/2024 at 02:55 #200545OotKustParticipantSame as most. End of line painting; then basing/ scenics, then matt spray all including the scenics to ‘fix’ in place.
When is important- never in same week as painting; at low humidity conditions, preferably warm dry sunshine (yes its done outside) and figures stay out there for at least an hour or so.
Also to avoid blotchy spray, I keep the cans in our hot water cupboard (you know linen??) so they are warmed up before the spray process. Ditto if Winter like now and 5ºC outside, figures sit on a sunny window shelf to allow spray to adhere to ‘warmer’ figures etc.
d
